Hello,
I’m not a Windows person so i’d like some help about asp components for my customers.
They would like to know, are the following components from PERSIST company.
Components are:
AspUpload
AspJpeg
AspEmail
AspImage
Also, what is AspImage image for?
Thank You
Tom
all of those you listed are supported:
http://jodohost.com/windows.asp
As for what each one does their website covers it well:
http://www.persits.com/
Thank You Stephen,
So I guess those all are Persist components?
Is AspImage actually AspJpeg?
Actually ASPimage is a server objects program.
They are very similar, but different makers.
That is the only one from the list not made by persits
[QUOTE=tomzzzy]
Hello,
Components are:
AspJpeg
AspImage
Do not use ASPImage, or let your customers use it. It causes memory problems on the servers. Use ASPJPEG instead. It’s just as easy to use, has all the same features, and it much more well behaved.
