ASP Components
Hey, do you guys ever think you would install n software’s IP*Works?
/n software - Cross-platform components and libraries for Internet Communications and Security
It has a ton of cool stuff to program with for ASP.
I use their components in my ASP script now and would need them for my site to work on jodohost.com
Jason
Looks like a lot of stuff that can readily be accomplished using native .Net code. However, you can just get their .Net version anyway and place their library in your own directory and you’re done… no Com components to install and register.
-Dave
Well I’m not about to shell out the $495 they want for it. lol
I’m just wondering if they would ever install it because I don’t feel like spending all my time in .NET re-creating the wheel.
-Jason
Woah! I didn’t realize the price tag on that one!
-Dave
TekniDude,
We will be considering IP*Works in a couple of weeks. Right now we are busy with some reorganisation tasks we are performing on our cluster.
Awesome, hope you guys go with it.
Thanks for the response.
-Jason
