ASP Enterprise Manager, MSSQL
I need to help a client setup XCAuction software to test on the jodohost servers. I don’t have experience with ASP and MSSQL.
The software installation is pretty straightforward, but I need some help setting up the MSSQL database, ODBC, and some sort of MSSQL admin utility.
I created the MSSQL database and user, but I need to run the sql install scripts. I’m unsure of the next step. I downloaded ASP.NET Enterprise Manager, but I’m at a loss how to compile and use it.
Looking for some direction,
Brent
The best tool to run sql scripts is Microsoft Enterprise Manager. You can download a copy of it from www.asp.net . It comes with MSDE
To manage your database online, www.aspenterprisemanager.com is good but its limited. We can run those SQL scripts for you if you want, just submit a ticket. You could write an ASP script that runs them
can mail me for this
[QUOTE=soundcompanies]
Brent
