Asp error - MDAC?
i’m getting an intermittent error -
An exception occurred: ‘Open’
this KB article seems to point at a solution, can support tell us what the status of this is - Microsoft Support
thanks
what server are you talking about? (windows 2003/ windows 2000 can make a big difference in any issue)
Edit: we are running mdac 2.8 however, so this should not be an issue, I most certainly will need the server and possiblydomain to check this.
its win5, and i am now getting a LOT of "unspecified error"s on pages that just a few mins ago worked fine.
also ticket 51149 with domain info
It is resolved now, IIS on win5 has been up for a long time, it seems that it was unable to process anymore ADO connections, I will be checking that out.
(IIS reset fixed it)
[QUOTE=Stephen]
yes, please do that. errors of this sort are not good. why not do a scheduled reset of IIS once in a while?
will strongly consider that.
