When I go to my site, the asp files aren’t being parsed, and instead I’m being asked to save them ( http://www.nursingoffers.com/ ) is this something I can fix on my end, or something you guys need to do?
Scott.
Scott.
Have you enabled ASP under Web Settings for this domain? If not, do so.
If that doesn’t solve the problem, submit a ticket. Might be some issue with mapping of .asp to its DLL here…
In the meantime, it might be a good idea to remove any sensitive information, like database passwords.
