ASP Graph Chart Control Advice
Hello,
Needed some advice of any 3rd Party Control which is installed on the servers - to generate Graphs / Chart !!! …
Ani
I think asp.net has its own graph charting object to do that.
and Office Web Components is installed from MS which can do that as well.
Thanks for your advice …
Am using ASP and not ASP.Net :frowning:
Any suggestions for ASP …
http://www.4guysfromrolla.com/webtech/LearnMore/Graphing.asp
That link outlines pretty much all the options you have
even in asp, you can still use the offic components installed on jodohost. although i have not had a chance to test this out yet.
