ASP.NET 2.0 question
I need to enable ASP.NET 2 for some sites. The plan has ASP.NET enabled and activated, but when I try to enable ASP.NET and choose version 2.xxx from the user control panel, I get “Error. Application Pool can’t contain ASP NET resources with different versions”. I’m not using ASP.NET 1.xxx for any sites.
What do I need to do to get ASP.NET 2 working? My sites are on win17.
This is coming just because HSPHERE 3.0 doesn’t recognize application pool which we create manually in IIS. You need to send us domain name(s) in ticket. We will correct it.
