ASP.NET Load Times
Hi -
ASP.NET page load times are fairly slow.
We recently upgraded our resources and they are still slower than they really should be.
I know this is always an issue for ASP.NET regradless of host and that much can be done on the developers (coding) side.
However, can anyone recommend steps I can take on the server-side that might pick up the pace a bit?
Thanks in advance for any feedback you may have.
David
Disable debugging can help a lot.
Yep - that did it.
Thanks!
