Hello.
I am on win15 and I am trying to test an ASP.NET MVC app, but it doesn’t work quite right.
It loads ok, but the routing of the links is not working.
I am getting the not found link error.
Is MVC enabled on win15?
Thank you.
Hello.
Thank you.
MVC is enabled, you may need to send ticket for wildcard entry to MVC for routing to work as that is not enabled by default. (it is a per domain setting, and make some additional DDOS surface vector, not something we want to do in large scale, only for people that need it)
I’ve sent the ticket.
Thanks Stephen.
