ASP.NET versions
I have searched the forums about ASPNET / ASP.NET versions.
In Hsphere my customers can choose between 1.1.4322 or 2.0.50727.
In several posts I found out that on most of the servers ASP2.0 is upgraded to 3.5.
Does this mean that when a client chooses ASP.NET 2.0.50727 he gets ASP.NET 3.5 SP1 ?
Is 3.5 SP1 installed on all severs? Or only on all servers on cluster 2?
best regards and best wishes for 2010 to you all!
Jan-Pieter
ASp.NEt 3.5sp1 is on all but Win13 on cluster1, all other servers have it. the way IIS works, 3.0/3.5/3.5sp1 are all really just extensions of 2.0, so when you assign 2.0 it is really 2.0+3.5sp1 extensions.
Thanks for the quick reply!
