ASP not working
All the ASP scripts in one of my user’s domains do not work, they generate 500 Errors, I have switched off ASp and switched it back on using the control panel, and that didn’t fix it.
Perhaps IIS needs to be restarted for the domain.
Domain: gympieyouth.com
Server: win2
Luke.
probably need to have this domain switched to win4. I could be wrong though. :smiley:
No, if a 500 error is being generated it is a coding related problem. Turn off IE friendly errors from Internet Options > Advanced to see the exact error
ok, so i was wrong. lol. that’s happened before.
Sorry Yash, I should have known that, I have been using a different PC with friendly errors enabled.
SThanks,
Luke.
