ASP POP3 Component
Does Jodohost have a POP3 ASP component installed on their servers?
ASPPop3 is or can be installed.
what about an IMAP component?
id love to build my own Webmail app
and along with Hsphere API it’d be great
I don’t know of one we have with IMAP, if you can research and find a good one, PM me and I will consider installing it.
am not sure but i think the latest JMail has IMAP thought am not sure might of just been Pop they added http://support.jodoshared.com/images/smilies/old/confused.gif
here’s a handy script that will tell you what components are installed on your windows box. Checks for over 700 of the most popular…
http://www.bier-voting.de/objcheck/query.zip
[QUOTE=jmbeach]
maybe this tool can be published from the services pages (and made available on reseller plans) so that we can dynamically show alls coms installed on each server at any time.
That would be really nice. It’ll let us build the com based apps without second thought.
the problem with using it to dynamically show all components is that it shows ALL of them, so it’ll show all the default ones like the AdRotator and all the other common ones
