aspjpeg optimization
I have a script that I use but I wanted to know if anyone else uses a better script for smaller file sizes but still maintain a pure image?
This script takes the image and creates a thumbnail and optimizes the original image.
Here is my script
	jpeg.Open Server.MapPath(SavePath)
	originalW = jpeg.OriginalWidth
	originalH = jpeg.OriginalHeight
L = 100
jpeg.PreserveAspectRatio = True
If jpeg.OriginalWidth > jpeg.OriginalHeight Then
jpeg.Width = L
Else
jpeg.Height = L
End If
	jpeg.Sharpen 1, 250
	'Draw frame: black, 2-pixel width
	jpeg.Canvas.Pen.Color = &H000000
	jpeg.Canvas.Pen.Width = 1
	jpeg.Canvas.Brush.Solid = False
	jpeg.Canvas.Bar 0, 0, jpeg.Width, jpeg.Height
	adjustW = jpeg.Width
	adjustH = jpeg.Height
	If UCase(Right(strName, 3)) <> "JPG" Then
      strName = strName & ".jpg"
    End If
	thumbName = "thumb" + strName
	SavePath = thumbSavePath & thumbName
	jpeg.Save Server.MapPath(SavePath)
	jpeg.Close
	SavePath = originalSavePath & strName
L = 500
jpeg.Width = L
Else
jpeg.Height = L
End If
	jpeg.Sharpen 1, 250
	'Draw Text
	jpeg.Canvas.Font.Color = &H000000
	jpeg.Canvas.Font.Family = "Verdana"
	'jpeg.Canvas.Font.Bold = True
	jpeg.Canvas.Font.Quality = 0
	jpeg.Canvas.Font.BKColor = &HCCCCCC
	jpeg.Canvas.Font.BKMode = "Opaque"
	jpeg.Canvas.Font.Size = 10
	jpeg.Canvas.Font.Rotation = 270
	jpeg.Canvas.PrintText jpeg.Width, jpeg.Height-80, "(512RYDERS.COM)"
	jpeg.Canvas.DrawBar 0, 0, jpeg.Width, jpeg.Height
	jpeg.Close
[QUOTE=Ryders512]
You can look into the .quality method that allows you to change the quality of the JPG image. With something smaller than 100x100 I find I can drop the quality down to at least 60 or 70 without a real noticable difference. This can reduce the size of your thumbnails and reduce your bandwidth usage.
