many of these tinhgs work without such object in the /bin folder and are much more secure that way(not ssaying these directly) due to the nature of .net and it negates much need for having the insecure system based install.
Initially it didn’t work on medium trust but I emailed them and they sent back a modified version which worked. It looks like the released version does medium trust now. I tested it on JodoHost but abandoned my project before I really used it.
You can use .NET components like these in your projects without needing help from JodoHost.
I don’t believe he was saying you were, he was just saying that the means to wrapper it over it over into asp.net won’t function use to medium trust level really.
Other reply was correct as I said these asp.net files work out of /bin as well and no need to do systemwide installs.
All I wanted to highlight was, that there are newer options in .Net (like Jodohost claims to support ver 3.5 now) the components should also match the upgrades.
Maybe its a good idea to have some components available which work better with ASP.Net at least.
Really the difference was in asp such would not work at all, with asp.net you can do most all of the components yourself. It is a much more flexible language for shared hosting in this regard because it is so extensible.
