ASPNETDB, anyone knows how to get it to work ?
I’m using the ASPNETDB on a project I am building and I am not sure how to get it to work once I upload it onto the server.
If anyone’s got sample of connection string of something that could help. It’d be greatly appreciated.
are you uisng sql server 2000? or sql express? sql express is not supported here on jodo.
I’m using SQL 2005.
I found help in this very helpfull article
http://weblogs.asp.net/scottgu/archive/2005/08/25/423703.aspx
[QUOTE=Seb]
I’m using SQL 2005.
SQL 2005 is not supported across all accounts yet, so I don’t think you’ll be able to get this working 100%
