I get the following error when I launch the application:
An error has occurred while establishing a connection to the server. When connecting to SQL Server 2005, this failure may be caused by the fact that under the default settings SQL Server does not allow remote connections. (provider: SQL Network Interfaces, error: 26 - Error Locating Server/Instance Specified)
Description: An unhandled exception occurred during the execution of the current web request. Please review the stack trace for more information about the error and where it originated in the code.
Exception Details: System.Data.SqlClient.SqlException: An error has occurred while establishing a connection to the server. When connecting to SQL Server 2005, this failure may be caused by the fact that under the default settings SQL Server does not allow remote connections. (provider: SQL Network Interfaces, error: 26 - Error Locating Server/Instance Specified)
Source Error:
[No relevant source lines]
Source File: App_Code.pxoq6icm.6.cs Line: 889
Stack Trace:
[SqlException (0x80131904): An error has occurred while establishing a connection to the server. When connecting to SQL Server 2005, this failure may be caused by the fact that under the default settings SQL Server does not allow remote connections. (provider: SQL Network Interfaces, error: 26 - Error Locating Server/Instance Specified)]
System.Data.SqlClient.SqlInternalConnection.OnError(SqlException exception, Boolean breakConnection) +800131
System.Data.SqlClient.TdsParser.ThrowExceptionAndWarning(TdsParserStateObject stateObj) +186
System.Data.SqlClient.TdsParser.Connect(ServerInfo serverInfo, SqlInternalConnectionTds connHandler, Boolean ignoreSniOpenTimeout, Int64 timerExpire, Boolean encrypt, Boolean trustServerCert, Boolean integratedSecurity, SqlConnection owningObject) +737554
System.Data.SqlClient.SqlInternalConnectionTds.AttemptOneLogin(ServerInfo serverInfo, String newPassword, Boolean ignoreSniOpenTimeout, Int64 timerExpire, SqlConnection owningObject) +114
System.Data.SqlClient.SqlInternalConnectionTds.LoginNoFailover(String host, String newPassword, Boolean redirectedUserInstance, SqlConnection owningObject, SqlConnectionString connectionOptions, Int64 timerStart) +421
System.Data.SqlClient.SqlInternalConnectionTds.OpenLoginEnlist(SqlConnection owningObject, SqlConnectionString connectionOptions, String newPassword, Boolean redirectedUserInstance) +181
System.Data.SqlClient.SqlInternalConnectionTds..ctor(DbConnectionPoolIdentity identity, SqlConnectionString connectionOptions, Object providerInfo, String newPassword, SqlConnection owningObject, Boolean redirectedUserInstance) +173
System.Data.SqlClient.SqlConnectionFactory.CreateConnection(DbConnectionOptions options, Object poolGroupProviderInfo, DbConnectionPool pool, DbConnection owningConnection) +133
System.Data.ProviderBase.DbConnectionFactory.CreatePooledConnection(DbConnection owningConnection, DbConnectionPool pool, DbConnectionOptions options) +30
System.Data.ProviderBase.DbConnectionPool.CreateObject(DbConnection owningObject) +424
System.Data.ProviderBase.DbConnectionPool.UserCreateRequest(DbConnection owningObject) +66
System.Data.ProviderBase.DbConnectionPool.GetConnection(DbConnection owningObject) +494
System.Data.ProviderBase.DbConnectionFactory.GetConnection(DbConnection owningConnection) +82
System.Data.ProviderBase.DbConnectionClosed.OpenConnection(DbConnection outerConnection, DbConnectionFactory connectionFactory) +105
System.Data.SqlClient.SqlConnection.Open() +111
System.Data.Common.DbDataAdapter.FillInternal(DataSet dataset, DataTable datatables, Int32 startRecord, Int32 maxRecords, String srcTable, IDbCommand command, CommandBehavior behavior) +121
System.Data.Common.DbDataAdapter.Fill(DataTable dataTables, Int32 startRecord, Int32 maxRecords, IDbCommand command, CommandBehavior behavior) +162
System.Data.Common.DbDataAdapter.Fill(DataTable dataTable) +107
ShowsDataSetTableAdapters.ShowsTableAdapter.GetShows(Nullable`1 date) in App_Code.pxoq6icm.6.cs:889
[TargetInvocationException: Exception has been thrown by the target of an invocation.]
System.RuntimeMethodHandle._InvokeMethodFast(Object target, Object arguments, SignatureStruct& sig, MethodAttributes methodAttributes, RuntimeTypeHandle typeOwner) +0
System.RuntimeMethodHandle.InvokeMethodFast(Object target, Object arguments, Signature sig, MethodAttributes methodAttributes, RuntimeTypeHandle typeOwner) +72
System.Reflection.RuntimeMethodInfo.Invoke(Object obj, BindingFlags invokeAttr, Binder binder, Object parameters, CultureInfo culture, Boolean skipVisibilityChecks) +371
System.Reflection.RuntimeMethodInfo.Invoke(Object obj, BindingFlags invokeAttr, Binder binder, Object parameters, CultureInfo culture) +29
System.Web.UI.WebControls.ObjectDataSourceView.InvokeMethod(ObjectDataSourceMethod method, Boolean disposeInstance, Object& instance) +480
System.Web.UI.WebControls.ObjectDataSourceView.ExecuteSelect(DataSourceSelectArguments arguments) +1960
System.Web.UI.DataSourceView.Select(DataSourceSelectArguments arguments, DataSourceViewSelectCallback callback) +17
System.Web.UI.WebControls.DataBoundControl.PerformSelect() +149
System.Web.UI.WebControls.BaseDataBoundControl.DataBind() +70
System.Web.UI.WebControls.GridView.DataBind() +4
System.Web.UI.WebControls.BaseDataBoundControl.EnsureDataBound() +82
System.Web.UI.WebControls.CompositeDataBoundControl.CreateChildControls() +69
System.Web.UI.Control.EnsureChildControls() +87
System.Web.UI.Control.PreRenderRecursiveInternal() +50
System.Web.UI.Control.PreRenderRecursiveInternal() +170
System.Web.UI.Page.ProcessRequestMain(Boolean includeStagesBeforeAsyncPoint, Boolean includeStagesAfterAsyncPoint) +2041
Any help would be greatly appreciated.
