aspSmartUpload can't work
Hi ~
ticket no :44578
We write a upload function with aspSmartUpload on wincf.chung-mei.net server…
It can’t work !!!
the error message below …
"Server object error ‘ASP 0177 : 800401f3’
Server.CreateObject Failed
/mag/mag_ProductSave.asp, line 19
800401f3 "
Our website locate on “book2.fullon.com.tw” domain..
Thanks for you~
Ted
ASP nor ASP components are supported on our ColdFusion servers
Only ColdFusion, PHP and Perl are supported on them
Hi ~Yash
Sorry ~ I still can’t understand that what’s your meaning…
"wincf.chung-mei.net " is just a windows server and support ColdFusion …(administrator set it on H-SPHERE)
So the asp can run normally except for aspSmartUpload on this server .
Please check it kindly ~ http://book2.fullon.com.tw/
Thanks for you ~
Ted
ASP is running normally because we had to enable it for HSphere. But we officially do not support asp and asp.net on our cold fusion servers and will be removing asp sometime later
If you need asp/asp.net, create an account on a standard windows server
