ASPUpload Help
Trying to get ASPUpload working on win13 just can’t get it to do anything. Here is my code
Set Upload = Server.CreateObject("Persits.Upload.1")
Upload.OverwriteFiles = False
Upload.SetMaxSize 5242880	' Limit files to 5MB
Upload.Save("D:\hshome\<username>\<domain.com>\<directory>")
Set File = Upload.Files("txtEventSignUp")
If Not File Is Nothing Then
	strFile = File.Filename
	Response.Write("<font color=red>Uploading " & strFile & ".</font><br>")
End If
Set Upload = Nothing
<table>
<form method="post" name="frmUpload" ENCTYPE="multipart/form-data" action="browse_new.asp?mode=upload">
<tr><Td>Upload Sign Up Form:</td><td><input type="file" name="txtEventSignUp"></td></tr>
<tr><td><input type="submit" value="Upload"></td></tr>
</form></table>
Any ideas are apprecaited.
Try Upload.SaveAs :slight_smile:
The ASPUpload shared hosting settings are in place in the registry on the servers some it will report and error or otherwise not function if you just using .Save
That didn’t work either, hmmm
err?
Doh, it is actually wrong, my mistake.
SaveVirtual is the command
AspUpload.com -- Chapter 10: Using AspUpload in a Shared Environment
Hmm same result.
and no I don’t see any type of error. Just proceses but doesn’t actually do anything.
Please send me an email of PM with the url and where I can test I will see if any errors showing in logs :slight_smile:
PM sent. Thanks for helping.
Got it
	Set Upload = Server.CreateObject("Persits.Upload")
	Upload.SaveVirtual("/signupforms")
	End If
