Attn Resellers: IP Justification!
Dated: August 19, 2004
It is now very essential that resellers ask their customers to begin justifying dedicated IPs used by them.
To simplify the process, we have setup an unbranded IP justification form through which resellers can ask for justification from their customers. To setup this form, please refer to Step 2, Part 3 of the Reseller Step-By-Step Guide ( Step-by-Step Guide to setup Reseller Hosting at JodoHost )
Resellers are not required to justify their name server IP addresses, we do that internally. However, if you own a sub-account in your reseller account that is using a dedicated IP, you must justify it. All IP addresses used by you or your customers from a sub-account in your reseller account must be justified. Once you setup the justification forum, simply login via the concerned sub-account’s username and password to justify the IPs used by that sub account. Please do not login via your reseller username to justify. Only justify from the respective sub account
IP justification is necessary if you or your customers are using a dedicated IP addresses. IP address space is limited and ARIN (American Registry for Internet Numbers) is pushing hosting companies to promote name-based hosting and conserve IP space. They no longer accept virtual hosting as sufficient justification for a dedicated IP.
Direct JodoHost customers who have not justified their IP till date are requested to do so from http://ipdatabase.jodoshared.com
