Best way to use VPS?
I have recently signed up for the Value VPS with Plesk installed. Now I was wondering what will be sufficient for me.
I will be running appr. 5-10 small to medium traffic websites including a few custom applications. This is running now, and causes no capacity problems with the value plan.
But I have not yet set up my VPS to act as its own Name Server… How much capacity does the local DNS require from my VPS?
Currently all my domains use 3rd party DNS services (like mydomain.com or joker.com), but it would be great to use ns1. and ns2.myownvps.com)
If the value VPS is not sufficient, what will be the best way to go then? Upgrade to a plan with more memory OR sign up for another value VPS to run my main domain + DNS services…
If you have plesk running then the dns services are already taking up about all they ever will :slight_smile:
DNS is tiny, won’t be an issue
