Billing Customers and adding months
Does anyone know if there is way if a client buys a annual hosting plan, to be able to add months to there ending term to show in the billing section after the purchase. I relize a month plan a credit would be easy to handle this, but yearly plans are different and I would rather add months to there ending term date.
I don’t want to issue a credit or use the change of start up date options.
I have tryed different tweaks and looked into psoft forum, but can’t find the answer only to change the start date, theres got to be away to do this and change there ending term date and move it forward.
WebD. :baby:
You can only add additional credit, but cannot increase the end date, unless the plan term itself is changed.
