I’ve got a site I’m working on that uses text drawn from a MYSQL database.
When a user enters text that includes the British pound symbol ‘£’, it is displayed as a ‘ï¾£’
My char set is:
What am I doing wrong???
My char set is:
I think it’s related to how your MYSQL database charset is setup. Nothing you can do since you cannot modify the setup.
Try to use :
#chr(163)#
Thanks for the reply. Unfortunately, it is user generated content that is being stored in the database.
had the same issue
eventually had to change to UTF8
