C++ Programming
Would like to talk about using a C++ program that will find the smallest and largest numbers that are input by the user in a program.
[QUOTE=anuone]
Then talk :slight_smile:
Seriously, what you want to know? Sounds like a very easy program
Sounds like you want help with a homework assignment, am I right? Maybe you can supply a bit more information about what you need help on and we can point you in the right direction without giving away the answer…
-Dave
C++ Books http:\www.gotchas3.as.ro
http:\ www.gotchas3.as.ro
[QUOTE=anuone]
:slight_smile:
