I want start my own services thats include
HTTP Web Server
SMTP Server
Messenger Server
Media Server
I Developed it as Windows Application
Can anyone tell me how to run it and wich plan I should choose ?
HTTP Web Server
SMTP Server
Messenger Server
Media Server
Unfortunately, since the application is Windows and cant run on Linux VPS, your only option with us would be a dedicated server.
ok , what about ASP.Net Application works like a server , can I take windows reseller Instead of dedicated server. ?
yes, you can run asp.net applications from a reseller plan. But you couldn’t run EXEs
I converted my source code to ASP.Net Application, I tested it on free asp.net hosting but my server didn?t work on the internet it worked on private network (IP=10.0.0.12, Port=8882)
On your standard windows hosting there is 1 Free Dedicated IP, can I use it to make my server work on the internet?
