Can't access control panel
Can’t get at it here, or from the main page of the site.
http://cp.jodohost.com:8080/psoft/servlet/psoft.hsphere.CP
Main Page
http://d470932.jd35.jodohost.com
Control panel has been down all night and no mention of the problem here! What’s going on?
control panel is was only down for 15 minutes
It’s up and running right as of now.
You can verify this from http://www.amegaproxy.com
what do you get when you ping cp.jodohost.com
There was an IP change for the control panel. So this may be due to ISP caching issues for some customers
what error are u getting?
The full link http://cp.jodohost.com:8080/psoft/servlet/psoft.hsphere.CP is working fine now. I did a ping on cp.jodohost.com as you mentioned in your other message and reported that IP address. That link doesn’t work. But the full/long link works now.
Next time you’re going to do an IP address change that could render the control panel unreachable for up to 24 hours you should post a way to get to the control panel via the new IP address that we can use for that 24 hour period.
Thanks Yash!
