Just an update, we are still working on this. This seems to be a very complicated problem and we are trying to fix it without having to bring down any servers.
Not sure if this is related, but if you go to http://www.chillywhack.com you will notice a VERY serious error.
are you connecting via the host name… mssql4.jodohost.com?
Please use Enterprise Manager and double check if you are able to login properly. If not, tell me what error you are getting and we’d look into it
Thing is, everything worked with the site this morning around 9 or 10am PST and has been up since the Datacenter move/issues.
I do understand that, but I tried to put oscommerce connecting to mysql.stamina-solutions.com and I get the can’t connect to mssql, but if I use the ip instead no errors occured!
What are you trying to connect to? MySQL or MS SQL?
From your post you seem to be mixing up the two, but they’re distinctly different things.
I don’t see a reason for the inconsistency between using an IP and the hostname you mentioned, as it resolves correctly to the IP mentioned earlier in the thread.
[QUOTE=SubSpace]
