Can’t Send Email - Solution
It took quite a bit of searching, but I finally found the answer to my problem in this thread:
http://support.jodohost.com/showthread.php?t=4761
My issue was I could not send email through my domain (mail.domain.com) even though I knew I had everything configured properly in my email client. After a bit more research into the matter after I found that thread, I found out that most (if not all) ISP’s are now blocking outbound port 25 these days. Changing the outbound port in my email client from 25 to 587 resolved the problem. It might be helpful to others having this problem in the future if someone made a sticky/announcement with the solution in this forum.
Hope this helps someone else.
techfuzz
