Something on CF2 is abusing badly every few hours, it slows entire service to a crawl making problems for all.
Re: CF2 abuse - working to find CF may be up and down
CF2 is being rebooted and even that is moving slowly due to this hanging made.
I am going to issue a chkdsk on this due to the slowness I suspect something could have happened with filesystem.
OS drive is done, User data is on stage 3 of 3, log drive is still to be scanned.
And log drive check went really fast, and starting up, hope this will resolve.
Re: CF2 abuse - working better
no issues since taking down and doing chkdsk, however we thought we had it fixed 3 hours before this post after it had a hiccup as well, but it came back and took more than 1-2 minutes to fix like it did the prior time.
It is happening again. CF1 and CF2 is responding slow at this moment.
we are checking it and update you again.
Server is up and working fine now.
Re: CF2 abuse - again slow
it is very slow again, last when it was working well I was able to get enhanced logging enabled and checking all that now.
Think we have found soemthing in logs, disabling CF on one domain.
We are getting a little slow again, checking it now.
It is fine now with no change only lasted about 45 seconds and it was just 2-5 second load times.
