I’m trying to add an RSS feed to my ColdFusion website and am running into an interesting error. The normal procedure to grab a feed is to perform a HTTP call to the server hosting the feed, parse the resulting file contents using CF and then loop through the resulting object.
Right now I am receiving the following error:
Error Occurred While Processing Request
Security: The requested template has been denied access to 216.167.96.124:80.
The following is the internal exception message: access denied (java.net.SocketPermission 216.167.96.124:80 connect,resolve)
ColdFusion cannot determine the line of the template that caused this error. This is often caused by an error in the exception handling subsystem.
This error is generated using the following code:
<cfhttp port="80" resolveurl="yes" url="http://216.167.96.124/arrl.rss"></cfhttp>
<cfset oHeadlines = XMLParse(cfhttp.FileContent)>
This should be a rather straight-forward setup, however in retrospect I wonder if the fact that CFExecute has been blocked (rightfully so) is having a negative effect on this issue as well.
Anyone run into this before?
