cfmail trouble
This code has always worked and now stopped. Our client uses it for sending a suggestion for visit to a friend.
Anything we should know?
Any changes server side?
replied already, but this line:
server=“mail.xxxxxx.com”
needs to be: server="[email protected]:[email protected]"
This enables SMTP Auth on CFmail
For everyone, apparently now we are supposed to use
where the capital XXXXX is the password for the mail account.
bah! Im too slow for Stephen chops :smiley:
well, for us it just simply stopped working. X(
No matter what we try. I have run out of creativity.
This is what we have there at the moment:
Please, can anybody point whats wrong?
and yes, I have tried the IP instead of mail.yyyyy.com X(
[QUOTE=Stephen]
or you can just change to
server=“localhost”
and not worrry about authentication :slight_smile:
Aslo, instead of putting everything in the “server” attribute, the cfmail tag also has “username” and “password” attributes.
So, an example:
Unless Jodohost has some setting in CF Admin set to disable the “username” and “password” attributes.
Also, if you set the “username” and “password” attributes, and also put the username:password in the “server” attribute, what is in the “server” overrides the others.
very annoying :open_mouth:
Doesnt matter which format I use, it works right when sending the message to outside Networks…but if I try to send to a mail box here… either does not come…or it takes several hours (around 6 or 7 hours delay).
Now, what can I say…?
Please, could anybody try to make that same test?
Do you receive inside the network here ok?
Thanks guys
Ok, it has improved to just over 1 hour.
Still… I’d like to understand the logic behind that.
thanks
