Cl1- Mssql10 Not responding
Currently Mssql10 is not responding, Looks like some node side issue. We are checking it and if needed then we will be move it to new node.
We have data copying to the new node now.
The power supply or motherboard is giving trouble on MSSQL10’s node and it was also the only server running on it, so moving it to a better node is the best option.
If all goes perfectly, we should have all data ready to boot the server in about 45 minutes now.
The server and SQL services are now LIVE.
The server needs one reboot now to make the installation of the new hyper-v tools live. This is to ensure hotswap and other features work properly.
We’ve got all completed and done looking good now. The main reason for needing that reboot was because the backup drive wasn’t being detected as it was added later (since we wanted to get the server up asap with core live data).
now with the drivers updated we can add and remove without further rebooted.
