Cl2-Win1 Urgent maintenance to solve IIS issue
We are needing to apply a MS hotfix for an issue that causes IIS to hang at times, we’ve had to do it on other servers when this issue cropped up, but it is a hotfix for only if the issue comes, not one to patch like normal.
The IIS has stopped responding twice today needing an IIS reset and seems to be doing it again so we are going to apply the hotfix to fix which will require a reboot.
Maintenance will be 5 to 20 minutes hopefully no more.
The hotfix is done, iis came up, but we are issuing a reboot to be sure it is fully applied.
