CL2-Win14 down
Server is down and Stephen is on way to DC to check it.
Power supply seems to be out, as it is not responding to power on button and was off when I arrived.
Sorry for the amount of time between updates, MSSQL10 will be up in just a moment, the hot swap system took a lot of extra work I did not expect to get the power supply swapped as it is a bit different than the rest we have in use (as we didn’t like the complexity of its wiring layout, for this reason)
CL1-MSSQL10 has been up, and now CL2-WIN14 is up all services. MSSQL10 had a totatally dead power supply, and WIN14 had one that was supplying too much power to the CPU and the mobo was protecting itself by not allowing it to function.
Seems some issue again, as server is not responding. Unfortunately we have no one in DC to check it right now, as this is physical server.
We all are downtown for holiday show and stuck in traffic, we will be there as soon as we can.
Stephen is checking and we will post an update soon.
Server is up now and we are checking it further to know root cause of down.
