Cluster 1 features
my account is in Cluster1, do I have the following?
  • CF MX 7
  • MSSQL 2005
  • MySQL 5
  • PHP 5
are they available on all servers?
If not, when can we have them like cluster 2?
They have been available for long, not on all servers as hsphere doesn’t work in such a way that they can be put on all servers properly that will not cause a wreck(like unix is not currently php switchable and moving everyone to php5 is a nghtmare)
mssql10 is 2005, web11/12 are php5, mysql6 is mysql5, wincf3 is cfmx7
so, if for example one of my client needs any 1 of those 4 … what do I have to do?
can you help me to configure / move the account? will i be charged any extra cost?
We can do an account move and move the account to a supported server for all except SQL Databases.
ic … so how do i get the latest sql version?
will creating a new account give them the sql2005 / mysql5?
making a new account will go to latest versions.
ok thanks for the reply stephen.
hi stephen,
1 of my client is on win27 & I believe it supports .net 3.5
but how to switch? I only see 1.1 & 2.0 in CP
and another client is on web12 … it supports php5
but how do I change it? the setting is not available in CP :frowning:
3.5 is in 2.0 :slight_smile: no need to switch even on IIS there is no such setting.
web12 is php5 only, there is no switching available on unix servers on 3.0
thanks stephen :wink:
Not a problem, that 3.5 ‘issue’ gets a lot of questions for forum.asp.net as well people saiyng it didn’t install right they can’t see it :slight_smile:
