Code payment gateway
Does anyone here have experience setting up payment forms with gateways? I have a client who got a merchant account from their bank to setup a payment form on their website. They use the ProfitStars gateway.
I don’t have much experience with this, and would be willing to pay.
Thanks!
Does you client have access to the ProfitStar merchant control panel? I use Quantum Gateway and within their control panel it gives me sample code to create custom forms.
Might be worth checking into.
Eric,
From your post above, I assume that you are using Quantum Gateway with Hsphere. If so, how did you integrate them? I am presently trying to do the same and am having problems. I’m being told by Quantum that they only have AIM emulation for AuthorizeNet but not SIM, which is what is available through Hsphere. Any advice on the topic would be greatly appreciated.
I use Quantum Gateway with WHMCS on my Win VPS. I know with Quantum under the management control panel they give me sample code to use on my web site. I haven’t taken a close look at the code and I’m not around my binder with my username/passwords so I can’t get too the code right now.
Ah, WHMCS, darn. Doesn’t look like Quantum will work with hsphere… You were my last hope! Oh well, I’ll have to suck it up and pay for AuthNet. Thanks for the response Eric.
Try CDG Commerce for your AuthNet account. Might be cheaper than directly going with AuthNet.
I’ll second the recommendation for CDG Commerce. They have a nice reseller program, through which I have a couple of client sites hooked up for ecommerce processing. Mostly those sites are running cart software (X-Cart or ZenCart) but one is running custom payment forms that I built using the PHP-AIM class from http://www.brkstudio.com/products/phpaim/ I wasn’t quite up for writing my own code for interacting with Auth.net.
Tim
