Can we get a sticky of what cf tags and cf functions are disallowed here at JodoHost, either here or on the public side?![]()
Bump
I will reply it later today, Mostly cfregistry but will check other servers too ![]()
Bump:)
Yes, some delay in today
I had real reason for it but won’t be sharing as it is more private matter.
However, CFREGISTRY is disabled tag, others are available.
Are there any functions disabled?
There is a script I have that works here on my dev machine, but not there. I would like to setup my local server to as close to what is setup at JH.
So, only CFREGISTRY is disabled?
yes only cfregistry feel free to send me a link to the script and I’ll check it out, if you have a static IP I’ll even assist you some in debugging the issue.
