I installed MSDE from my MS office 2002 CD. Using MS access I created a project and then a database in MSDE. My question is when I connect to my datatbase, in my ASP code do I where I write the connection string do I put down the project name? or the database name? I noticed that the MSDE saved the project in the folder where i wanted but the database belong to that project is some other folder?
My second question is when you create MSDE database using Access as front end application is it possible to by pass the project and just make database straight?
