hi. i have recently npticed that i cannot connect as usual thru DW. i can connect fine with FlashFXP, but not with the FTP thru DW.
any tips?
thanks!
any tips?
thanks!
It works for me. What error are you getting?
“first that it cannot connect.” that then “cannot syncronize because time cannot be determined” that then “connect bla bla bla…”
:rolleyes:
are you dedicated ip or shared?
dedicated…
i’m trying to connect to “win2.jodoshared.com”. maybe that the reason?
then again i’m connecting like that on FlashFXp too and it seems ok (although it disconnects very quickly… different story)
If you are dedicated IP then switch dw to that IP.
works like a charm.
thanks! :))
