Hi, I am considering Jodo as my new host. I like my present host but I am forced to leave because of their limited Microsoft based features. I have narrowed my search down to two hosts, Jodo and ASP*** so I want to ask you a couple of questions that will help me decide which to choose.
[ol]
[li]ASP*** offers SQL2K5 64bit Server, do you plan to install this version in the near future?
[/li][li]Is it possible to remote connect with Enterprise Manager, VS.Net? (Including viewing db schema, tables etc)
[/li][li]ASP*** offers 2GB of disk space for each email account and 1GB for each database created, this is in addition to the disk space allocated for files pages etc. How do you handle disk allocation for DB and Email?
[/li][li]Do you offer or support the following, Microsoft SOAP Toolkit 3.0, XML 4 SP2, WinHTTP 5.1, ASP.NET Mobile Controls, IE Web Controls, Sub Web Applications, MDAC 2.8?
[/li][li]ASP*** offers Unlimited dedicated IP’s for a $3 onetime setup. How do you compare?
[/li][li]Does your server utilize any Raid Disk Arrays? (0,1,5 etc)
[/li][li]Are all of your servers duel Xeon config? Also which Xeon CPU do you use?
[/li][li]Which version of Win 2K3 server are you using? (Standard, Web etc.)
[/li][li]What is the memory type and size installed on your servers?
[/li][li]How many accounts do you allow p/server?
[/li][li]Do you offer and support DonNetNuke?
[/li][li]ASP*** supports CommunityServer which has Blogs, Forums and other usefull portals, How do you compare?
[/li][li]In the near future I will want to offer hosted business applications to my customers, is there any way to add such custom features in the Control Panel plan configurator?
[/li][li]Do you offer merchant accounts/payment gateway etc?
[/li][/ol]
I think thats about it for now. I thank you in advance for you time.
