Does anyone know of a built in feature within H-Sphere to create a demo account?
I’d like users to be able to give the control panel a test while deciding to signup etc.
Or has anyone got any tips on creating one?
Thanks!
Thanks!
Start a new plan under plan wizard. At the very bottom of the Plan Creation Wizard Step 1 the last option, you will see the Demo only mode, check box.
You can create 2 seperarte ones for a Linux & Windows server.
From memory, demo accounts dont count towards to your total allowed accounts does it? Or am i dreaming?
Nope don’t count. Not sure after 2 if it does tho.
