We are facing erratic problems with our Control Panel causing it to go offline and online for the last 24 hours. Therefore if you are trying to perform any activity using the control panel you may be facing problems. We are sorry for the inconvenience and are working on this problem presently. We will post further updates here. It should be noted that no websites have been affected by this problem
The Control panel issue has resurfaced and we are working to put a permanent end to this problem. ftp, mail, web or database services haven’t been affected by this
