Control panel logins?
Hi.
For some reason the control panel doesn’t like my login credentials.
I’ve tried my own and one from a client and they both were rejected, so I’m fairly sure it’s the CP.
Do you think it’s a problem on my end, or is the control panel in the middle of some configuration?
I didn’t see any notifications in my email. Sorry if I missed it if it was sent.
Edit 8:06PM EST
Both logins are now working. Very strange.
there are two clusters, maybe you were on the wrong one?
Well, I used the control panel I’ve always used.
The client login was a very old one. Probably one of the first 4 or so. Anyway, it could have a been a browser issue on my end to.
Thanks, Stephen.
