Control Panel problem
I’m currently unable to log into the H-Sphere control panel. It just sits at the login screen indefinitely after I’ve pressed login.
Anyone else having this problem?
Currently the backup is running, due to which you are facing this issue.
CP will be back to normal within some time.
Should be working fine now.
