Control Panel URL Dosent Work
I am using the following address to get to the control panel, its the one i was give when i set up the account and as far as i know ive not been sent a new one, but it dosent work, just says it cant find the page.
http://cp.jodoshared.com:8080/psoft/servlet/psoft.hsphere.CP
Thanks for your help,
Jack
Are you behind any firewall that may be blocking port 8080 (the port the control panel is running)?
Sorry for the late reply. Yeah that could well be the reason. Not a problem though. Cheers for your help.
Jack
