Unable to query Reseller CP by domain or generic search. The following error is generated:
[I]Error getting report: An I/O error has occured while flushing the output - Exception: java.net.SocketException: Broken pipe
Stack Trace:
at java.net.SocketOutputStream.socketWrite0(Native Method)
at java.net.SocketOutputStream.socketWrite(SocketOutputStream.java:92)
at java.net.SocketOutputStream.write(SocketOutputStream.java:136)
at java.io.BufferedOutputStream.flushBuffer(BufferedOutputStream.java:65)
at java.io.BufferedOutputStream.flush(BufferedOutputStream.java:123)
at org.postgresql.core.PGStream.flush(PGStream.java:411)
at org.postgresql.core.QueryExecutor.sendQueryV3(QueryExecutor.java:33
at org.postgresql.core.QueryExecutor.executeV3(QueryExecutor.java:121)
at org.postgresql.core.QueryExecutor.execute(QueryExecutor.java:100)
at org.postgresql.core.QueryExecutor.execute(QueryExecutor.java:43)
at org.postgresql.jdbc1.AbstractJdbc1Statement.execute(AbstractJdbc1Statement.java:517)
at org.postgresql.jdbc2.AbstractJdbc2Statement.execute(AbstractJdbc2Statement.java:50)
at org.postgresql.jdbc1.AbstractJdbc1Statement.executeQuery(AbstractJdbc1Statement.java:233)
at psoft.hsphere.report.adv.DomainSearchReport.init(DomainSearchReport.java:80)
at psoft.hsphere.report.AdvReport.exec(AdvReport.java:104)
at freemarker.template.expression.MethodCall.getAsTemplateModel(Unknown Source)
at freemarker.template.instruction.AssignInstruction.process(Unknown Source)
at freemarker.template.compiler.TemplateArrayList.process(Unknown Source)
at freemarker.template.instruction.IfInstruction.process(Unknown Source)
at freemarker.template.Template.process(Template.java:287)
at freemarker.template.instruction.IncludeInstruction.process(Unknown Source)
at freemarker.template.Template.process(Template.java:234)
at freemarker.template.Template.process(Template.java:255)
at psoft.hsphere.CP.service(CP.java:896)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:802)
at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:252)
at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:173)
at org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:213)
at org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:178)
at org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:126)
at org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:105)
at org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:107)
at org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:148)
at org.apache.jk.server.JkCoyoteHandler.invoke(JkCoyoteHandler.java:199)
at org.apache.jk.common.HandlerRequest.invoke(HandlerRequest.java:282)
at org.apache.jk.common.ChannelSocket.invoke(ChannelSocket.java:754)
at org.apache.jk.common.ChannelSocket.processConnection(ChannelSocket.java:684)
at org.apache.jk.common.ChannelSocket$SocketConnection.runIt(ChannelSocket.java:876)
at org.apache.tomcat.util.threads.ThreadPool$ControlRunnable.run(ThreadPool.java:684)
at java.lang.Thread.run(Thread.java:595)
End of Stack Trace[/I]
