CP not allowing login - resolved
The CP is not allowing login to anyone including admin level logins, we are checking the matter on urgent basis.
Re: CP not allowing login - checking
We have found the issue, it is on the DB side, working to resolve it.
all is up now, the DB server had a kernel panic and had hung there, it required a reboot. We are researching the cause of the kernel panic as well.
