Cron Job's
I spoke to customer service and they stated that I can use many cron jobs with my linux plan. Is this true? My website requires cronjobs to access my other accounts to download daily files.
Please let me know.
You can do cron jobs from your linux plan, about accessing other files, that possibly can be done if using web URLs.
Just make sure you setup the cron job properly, sometimes cron jobs get set that end up running in continual loops making some issues, if you have any questions or want guidance on it, feel free to open a ticket and ask for suggestions.
OK thank you. We will set up the crons properly.
Your customer service is superb!
where do I create the cron jobs?
nevermind. found it.
If you are going to bother posting a message that says “nevermind - found it” … couldn’t you at least mention WHERE you found it? Obviously it wasn’t easy for you, so maybe the next guy could use a hand as well.
Just a thought.
I will help you :slight_smile:
Obtaining Direct Access To Server - H-Sphere User Menu Based Guide - Positive Software Corporation
lol, thanks… i was just coming back to say “nevermind, found it.” :stuck_out_tongue:
Thanks stephen.
