Guys… I have the similar issue. Your help/assistance will be appreciated…
I had the scripts running and connecting to MS Access… and all works dandy
But when I try to make it work with Oracle Database… and when I try to ADD record, I get the Error.
Error Type:
ADODB.Recordset (0x800A0CB3)
Current Recordset does not support updating. This may be a limitation of the provider, or of the selected locktype.
include/DocInfo_aspFunctions.asp, line 188
It suggests that Line 188 is in Error
The following is my code for that page:
[CODE]<%
function DocInfo_QryStr
'strqry=“SELECT UNIQUE_ID, DOCUMENT_TYPE AS [Document Type], PROPERTY_ADDRESS AS [Property Address], " & _
’ " POSTAL_CODE AS [Postal Code], LAST_NAME AS [Last Name], " & _
’ " FIRST_NAME AS [First Name], Left([Document_description],50) AS Description, DOCUMENT_LOCATION AS " & _
’ " [Document Location], REGISTRATION_NUMBER AS [Registration Number], DOCUMENT_DATE AS [Document Date], " & _
’ " COUNCIL_APPROVAL AS [Council Approval] " & _
’ " FROM DLTS_DOCUMENT_DETAIL "
strqry=“SELECT Unique_Id, DOCUMENT_TYPE, PROPERTY_ADDRESS, " & _
" POSTAL_CODE, LAST_NAME,” & _
" FIRST_NAME, Document_description As Description, DOCUMENT_LOCATION,” & _
" REGISTRATION_NUMBER, DOCUMENT_DATE, " & _
" COUNCIL_APPROVAL" & _
docinfo_qrystr=strqry
end function
sub MainMenu
Document Management System |
<% if session(“admin”) then
tbsz=300
else
tbsz=200
end if
<% if session("admin")=0 then %>
<td align="center" width="100" bgcolor="#000000"
height="10" onmouseover="this.bgColor='#772299';" onmouseout="this.bgColor='#000000';"><a href="docinfo_login.asp"><font color="#FFFFFF"
size="1" face="arial"><b>Login Admin </b></font></a></td>
<% end if %>
<% if session("admin")=1 then %>
height="10" onmouseover="this.bgColor='#772299';" onmouseout="this.bgColor='#000000';"><a href="docinfo_edit.asp"><font color="#FFFFFF"
size="1" face="arial"><b>Add New </b></font></a></td>
<% end if %>
</tr>
end sub
function RecExist(strqry)
set rs=server.createobject("adodb.recordset")
rs.open strqry, strconnection
if rs.eof then
RecExist=0
else
RecExist=1
end if
rs.close
set rs=nothing
end function
function RunQry(strqry)
recAff=0
set cnn=server.createobject("adodb.connection")
cnn.open strconnection
cnn.execute strqry, recAff
if recaff<>0 then
runqry=1
else
runqry=0
end if
cnn.close
set cnn=nothing
end function
Function Addnew_Street (dt)
dim rs
dt=ucase(trim(dt))
strqry="Select * from DLTS_LKP_STREET WHERE street='" & dt & "'"
rs.open strqry, strconnection, 2, 3
if rs.eof then
rs.addnew
rs("Street")=dt
rs("Municipality")="MARKHAM"
rs.update
end if
rs.close
set rs=nothing
End function
Function Addnew_DocType_Data (dt)
dim rs
dt=ucase(trim(dt))
strqry="Select * From DLTS_LKP_DOCUMENT_TYPE " & _
" Where Document_Type_Description='" & ucase(dt) & "'"
if rs.eof then
set rs_dtid=server.createobject("adodb.recordset")
strqry="Select (Max(document_type_id)+1) as new_dtid From DLTS_LKP_DOCUMENT_TYPE "
rs_dtid.open strqry, strconnection, 2, 3
new_dtid=1
if isnumeric(rs_dtid(0)) then
new_dtid=rs_dtid(0).value
end if
set rs_dtid=nothing
rs.addnew
rs("document_type_id")=new_dtid
rs("dococument_type_description")=ucase(dt)
rs.update
rs.close
set rs=nothing
end if
End function
function Update_DocInfo_Data(strqry, data, noFld, updtAs)
dim rs
dim rs_uid
if lcase(updtAs)="edit" then
if not rs.eof then
for i=0 to nofld
if isdate(data(i)) then
rs(i)=datevalue(data(i))
else
rs(i)=data(i)
end if
next
rs.update
updatedata="Data has been updated successfully"
else
updateData="Due to some error data could not be updated."
end if
end if
if lcase(updtAs)="new" then
set rs_uid=server.createobject("adodb.recordset")
strqry="Select (Max(unique_id)+1) as new_unqid From DLTS_DOCUMENT_DETAIL "
rs_uid.open strqry, strconnection, 2, 3
newuid=rs_uid(0).value
if not isnumeric(newuid) then
data(10)=1
else
data(10)=newuid
end if
rs_uid.close
set rs_uid=nothing
rs.addnew
for i=0 to nofld
else
rs(i)=data(i)
end if
next
rs.update
updatedata="New data has been added successfully"
end if
rs.close
set rs=nothing
end function
%>[/CODE]
