Am I unreasonable in being disappointed in the slowness of support responses?
I have placed a total of 10 tickets since joining Jodohost in February. Below are a list of the tickets and the time it took to receive the first response.
[FONT=“Courier New”]
Trouble ticket hr:mn
DOT-67248-339 03:41
EHJ-27923-392 17:25
ADI-74251-979 05:59
CDK-65965-144 08:13
ORY-64359-254 02:19
EZR-17044-975 00:07
SUV-10526-709 02:09
JOR-63767-365 00:25
ASW-82704-253 03:48
EKY-67618-197 04:55[/FONT]
Note that the times are for first response, not resolution. Times of 3, 4, 5, 8 & 17 hours are, in my view, unacceptable for a reseller, and even 2 hours is stretching it. We have to respond to our customers, but it is very difficult when we are completely in the dark. Anyone care to comment?
The last ticket is still open. After I replied to their first response it has taken another 10 hours to get a reply (which happened as I was composing this message).
I even used live chat about 6 hours ago to check on progress. After I referred them to the ticket number, the response was it was being referred to a higher level and they would contact me soon. Since when has 6 hours been soon?
While I accept the difference in time zones may, at times, cause delay if 1st level support cannot resolve the issue, I cannot accept being kept waiting for 10 hours without any indication there may be some delay. And then they haven’t answer my questions.
So in desperation, I have come to the forum to seek the answers.
The problem:
Yesterday, I discovered mail sent from one of my customers was not being received – even if sent to other Jodo hosted mail accounts. This applied to both pop3/smtp mail and web mail. The mail client / browser indicated the mail was successfully sent. But it has yet to arrive. I created a test mailbox under the user’s account and got the same result. Mail appeared to be sent but it never arrived.
Overnight, Support replied to the ticket advising that the queue on mail five had been high, delaying mail, but it should now be ok. It wasn’t.
None of the test mail had been received (still hasn’t). The customer could successfully send mail (and have it received) via both pop3/smtp and web mail. However, using the test mail account I had created, I could successfully send by web mail, but pop3/smtp failed with this error:
Recipient error [451 Dynamic/Residential IP range listed by NJABL dynablock - http://njabl.org/dynablock.html]
A bit of testing revealed that the error only occurred if a pop3/smtp connection was made from my IP address block to any mail account hosted on mail5. Mail accounts hosted on mail4 were unaffected.
I asked if, as my tests indicate, it was my IP address being rejected, is mail5 testing authenticated users against the NJABL dynablock listing. If so, should it be? I thought the NJABL dynablock listed known dynamic and residential IP addresses, and being listed permanently is the eventual prospect of all such addresses. I thought it was useful only for checking smtp servers and of no use for testing user mail accounts. I possed the above questions on the ticket and asked if mail was still queued, as none of the test emails I send had been received yet.
10 hours later, I am advised that Jodohost mail servers had been “unblocked by njabl.org a while ago but we forgot to update you.â€. Unfortunately they didn’t answer my queries and the problem still persists. The customer also has a dynamic IP address, and some (but not all) of the blocks allocated to his ISP are listed in NJABL dynablock. My concern is that sooner or later, he too will find his IP address listed. The same concern applies to most of my customers.
Can anyone confirm if my theory about the Recipient Error is correct, and is anyone else experiencing delays on mail being sent via mail5?
