I want to use DNN’s hosting capability to manage client sites. I will be hosting sites that are industry-specific and fall into 2 different industry categories (ie, airplanes or boats). Each industry will have modules specific to their industry and share SQL Server dbases. Therefore, I will have 2 DNN “hosting” sites to accomodate each industry’s specific needs. Under the Reseller plan, what is the best setup in this scenario? Should/can I have 2 Service accounts (ie, www.boats.com and www.airplanes.com hosting www.boats1.com , www.boats2.com and www.airplanes1.com , www.airplanes2.com respectively?). Along these lines, are other DNN Hosters doing anything similar and what works best under JODO’s Reseller Plan? I currently have a DNN 3 Service Plan for “boats” and want to setup “airplanes” using DNN 4. Thanks for any advice/comments.
We have a number of customers doing this, it works pretty well.
You don’t really need to service plans to do this, you could do one in a service plan and in a plan with no billing, or you could do it all in one account for dnn3/4, but I’d recommend using 2 just to keep them in manageable order and a bit more “seperate”
